This entry is being made several days after the event. I started on the rear throttle kit. The plans call for the removal of some nut plates that are on the bulkhead and armrest flanges. So I dutifully removed them and used my squeezer to flatten the dimples. I then fit the rear throttle mounting panel into position and clamped it in place. Next I made copies and cut out the template that shows you where to cut the slot in the armrest for the rear throttle. As it turns out there are two predrilled holes in my QB kit that matched perfectly with the template. I called it quits for today and will cut the slot later on; I need to pick up some more cutting wheels for the Dremel.
Nut plates removed per the plans for the rear throttle kit
Plans call for the panel on the insdie of the flanges but many have put the panel on the outside
These holes werer already drilled on my kit, They match the template slot locaton perfectly.
