Brief Description: Drill pedal extensions to pedal
I am late getting this entry in put not much done on the plane in October. I worked a fair number of the days and when I was home I was working on household items. The only thing I did to day was drill the pedal extensions to the brake pedals. I installed one pedal to double check the fit and add some rivets into the hole (not bucked) to see how I like the look of the raised head rivets. I plan to get the parts color anodized and then rivet them together, this way I will get the gold color of the rivet against the color of the pedals.
I finally got around to another task and that was to cleco on the instrument panel. I want to customize my side consoles and I need to sit in the plane and get a feel for where my arms will reach. This will help in the layout of the cockpit switches and circuit breakers.
Drilled to pedal
Test fit to rudders
Instument panel clecoed in place so I can test reach for switches
