I finished up honing the left rudder pedal. The left side took a lot of honing; the raised area is right where the uprights for the pedals are attached to the ruder pedal main rotation tube. After I had the left pedal rotating smoothly I installed two nylon blocks to the ends. These blocks hold the pedals onto the main support but also support the outer edges of the assembly. They are not attached to the floor but float and slide with the main assembly. I drilled the holes for the AN3 bolt that will secure the block to the rudder pedal assembly. And of course what does every drilling require…. Deburring!
Slide block retains rudder pedal and slides on floor as pedals are adjusted
