Brief Description: Riveted on bearing to F-841 tube
I drilled the bearings to the F-840 and F-841 tubes day before yesterday but still needed to deburr the holes so I did that today. I have been fighting a cold so not inclined to do much work in the shop. The instruction say to rivet the bearings onto the large tube before you prime them since the primer will make installing the bearing and aligning the holes difficult. You can easily pour primer into the threaded hole so I went ahead and riveted on the bearings. I failed to take a picture of this so this entry will be sans pictures.
