Not getting in many hours these days but in the couple I did spend today I sanded the cowl corner so I have a nice fit between the upper and lower cowls at the sides. I still have one baffle screw to install and this is the one behind the oil filler tube. I had to remove the tube in order to get this screw installed. Not I will have to safety wire the filler tube but I will wait to make sure I don’t have to remove the baffle again first.
