Well I took a step backwards today. When I re-clocked the prop governor arm yesterday I did not read the instructions correctly, well actually I read them correctly a long time ago but did not remember them correctly. I removed all of the screws from the back of the governor instead of just loosening them, you are supposed to only loosen them and rotate the arm to the desired position. I put it back together; there is a spring and counter weight looking items. It all seemed OK but I thought I would call American Propeller and ask. Well they asked me to send the unit back I guess they will need to make sure I did not mess anything up, so hopefully that will not take too long or cost too much. I am just glad I asked.
Still waiting on some gaskets so my work on the engine will be put off for a while besides I work most of the time between now and the end of the month.
What's wrong with this picture, no governor that's what!
3 of the screw have to come out to mount the bracket, you just have to keep the others tight.
