Red banner day today, I was actually able to actuate a switch and see something come on that was not temporarily hooked up. I pinned out the small Molex connector, this one sends power out to the cockpit lighting and the exterior lights. I really like how this is turning out but it sure is slow. I hooked up the battery and master relay switch and powered up the panel. I hooked up a NAV/STROBE light just to test the progressive function of the switch, first position is NAV lights only and second is NAV and STROBE. The map light and interior side LED lights are already hooked up and worked as planned. I did have to swap terminals on the map light switch, it was hooked up opposite of how I wanted the switch to work. The idea is the “OFF” position for all switches is either down or inboard.
I then turned to the more mundane task of organizing and tying off the main bundle that runs across the cabin. Since I have had to cut away parts that I have spent hours tying I wanted to wait until I was sure not more changes would be required of this bundle. There is still lost more to tie up but this is a start. I will do the rest once I have the reminder of the circuits hooked up.
Nav/Strove ligth working!!! You can also see the interior blue LED and teh red MAP light
I had to add labels so I knew what went where from the back.
