The wires behind the panel are getting thick; I forgot that I can wire the two autopilot servos together so I can save myself 6 wires behind the panel by tying the two servos together under the floor. I attached a terminal block to the side of the aileron trim bracket. I drilled holes to run the servo wire from the right wing to the area by the aileron trim bracket. I spent a lot of time in the shop but most of it was head scratching. I feel like I am almost to the point where all of the design stuff is done and I will make some real progress but each time I solve one puzzle another one crops up.
