Brief Description: Made support for rear of radio stack
Well after getting idea from other builders I made a bracket to support the rear of the radio stack. This turned out really good; the radio stack is now rock solid and should handle any G-loads I might experience. I also installed nut plates where there will be cushion clamps, it seemed silly to fumble with washers and nuts to install these clamps.
To remove the panel I can remove the Garmin 496 which will be in the center bottom hole in the panel, I can then reach in and remove the screw that holds the bracket to the cross brace. With the service loop in the wiring I have planned, I can then putt the panel in to my lap and disconnect things from there, or at least that is the plan in theory.
This holds the stack nice and solid
You can see the clearane for the antenna connectors.
