I refined the hard AOA/Pitot lines that will run under the left console. I then installed the instrument panel to check for clearance of the Garmin 430. It gets very close to the cross brace so I need to find some way to support the radio stack. Under G-loading I think it might sag enough to touch the brace. My plan is to make a support but also put plastic tape in the area so there can be no grounding, also to prevent chaffing. I will have to consult some builder on how they handled this.
Look at all those wires!
The back of the Garmin 430 will touch under G-loads, I need a brace here
