Brief Description: Started to rivet (R) bottom skin
Finally back to work on the place. I have been home for a few days but decided I needed to get work done on a flat bed trailer I am going to use to move the plane to the hanger. The trailer needs new boards but after removing the wheels it will also need new brakes. They are on order, should be here Tuesday, some sanding and paint and new boards and this will be a nice trailer.
I started the right wing bottom skin this time totally solo, I had help from Uncle Jack to get the left one started. It was not too tough though to get started. I managed to rivet the rear spar through the 4th bay and everything else at an angle from there. It should be fairly easy going from there. Maybe tomorrow I will have the wing done.
7x16 trailer for the move to the airport
Rear spar done through 4th bay, this is the tough part
