I finished the right wing riveting, this side I did totally solo. I did almost make a major mistake. I had one rivet in the corner of the 4th bay that required a longer rivet. I skipped it thinking I would work a little farther then get back to it. Well I almost closed up the bay so I would not have had access to it, this would have had to be a blind rivet but I caught my mistake in time to set a rivet in there. The seam between the front and real skins and the main spar turned out great. I don’t think a piece of paper would fit between them. I am tired, but the right went about 8 hours faster than the left, I did the right outer bottom skin in about 12 hours.
You can see the lone clecko on the left side, I almost missed that one
