I first pulled the left side wires for the lighting and tied them into their own bundle and then re-pulled them. I then made a standoff for the right side like I did for the left. This one had to be a lower which caused some issues when it came time to rivet it in place. I could not get a blind or bucked rivet in the lower hole with the bracket in place. I ended up pulling the lower rivet with from the front with the bracket 90 degrees from it position, I then rotated the bracket into place and pulled the upper attach rivet, all is good but this took some time to figure out..
I worked on where some attach anchors need to go to hold the wires down so they do not interfere with the aileron push rods. I used RTV to attach them to the floor of the fuselage; they should be ready to hold wires by tomorrow. I next secured the right side wire bundle to the gear weld mount using Adel clamps and tied the short section of wire between the weld mount clamp and the standoff I made earlier.
I started to work on the left wire run, I realized that the route I was going to use for the wire to keep it above the fuel lines makes it kind of close to the rudder cable. I will have to see if there are other options. It was time for 60 minutes and dinner so I called it a day.
Adel clapms hold wire nice and secure, tied of with lacing cord
Zip-tie will hold wires to the plactic bracek and keep from interfering with aileron pushrod.
Rudder cable a littl too close to wire bundle, I need to run the wires lower if I can.
