Well the day got away from be for I am not sure why and I only put in a couple hour on the plane. I organized the left side wires with zip ties which will come off once I tie the bundle with lace cord. I had to install a nut plate to hold a cushion clamp on the forward side of the F-802. I did not want the wire bundle to interfere with the engine control cables. More work tomorrow I guess.
This is foward side of F802 Bulkhead
Clamp and zip tie anchor will hold bundle away from idler arm (removed)
