Brief Description: Made bracket to hold Molex connector
After thinking on my issue with the CB panel I have come up with a new idea. I made a bracket that will attach to the circuit breaker panel, this bracket will hold one side of a Molex connector. The other side of the connector will be attached to the switches. The idea is the wires run from the switches will be bundled together and long enough to have a loop that will allow the panel to be opened enough to disconnect the Molex connector and let the CB panel open up more fully. The wires going to the other CBs should have enough play to let the CB panel open enough for the desired access.
