Ron Lendon's Aircraft Mfg.
Date:  11-18-2010
Number of Hours:  3.00
Brief Description:  Fit bottom skin doubler 6ZU2-9
Riveted 6B5-2 back to the original holes in the floor, everything is falling into place.
Removed center spar and used it to transfer holes into 6ZU2-9.
Then took that piece and positioned it on the bottom outer skin and use it to back drill through the skin to elongate the holes in the skin forward row. Everything moved .125" forward with the upgrade.
Copyright © 2001-2021 Matronics. All Rights Reserved.
