Brief Description: Weld and finish lower engine mount bracket
Put brackets in position and transfered holes from firewall.
Balanced bracket in angle vice with level in both directons. Didn't really like the position of the transfered hole center so I made the hole central in the tab and cheated the firewall open to the bracket.
Didn't have the bolts I needed so I called Bob Hunt and made a trip up to his place to get the two he had.
Gonna need to go longer than AN6-7A because the WW mount tubes are 1.625" long.
