Brief Description: Make tool for nut plate rivet spacing
Took piece of .25" aluminum and made a quick drill guide just for the Z-angles around the bottom access holes. .25" spacing in line does the trick. The center hole is in so it was just a matter of lining up the center, holding it and drilling through the other two holes. I may use flush solid rivets to get a better seal and finish on the door.
