Brief Description: Attach leading edge skin to right wing 1 of 3
Decided which leg would be bottom and trimmed it to length 411mm from the center of the bend. Filed the edge, sanded the edge, then red scotchbrite the edge. Marked two lines away from the edge, one at 10mm and one at 20mm along the entire length.
Set inboard edge 120mm inboard from the center of rivet line in rib 1. The two lines help line up the length. Clamped and transfered the NR locations to 6-W-8-1 on the 20mm line. Took the leading edge skin back off and layed out the rivet lines and rivet hole locations for the nose ribs.
