Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Remove rivets from Center Spar
Removed the A5 blind rivets.
Center punch, Pilot drilled, #30 drilled all solid rivets.
Knocked heads off with chisel, seperate web from spars.
Punched out rivets with 1/8" pin punch on the floor supported on end grain wood blocks.
Wire tied pieces together.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
