Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Distributor
Check advance degrees
Using a bump stop, check actual degree of movement of the distributor rotor with a protractor.
Then mark the rotor plate for notch.
Next find out outer limit of weight movement.
Bump Stop Mag Base
Protractor 11-12 degrees
Mark rotor plate for notch
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
