Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Distributor
Face off bottom bushing on Distributor
Took .048 off the end to provide .004 end play.
Cleaned it out real good with Brake Clean and brush. Ran shaft at 1500 rpm in distributor body with oil on bushings, no drag and no heat build up.
Soak bushings in oil so they can drink it up.
Soaking up oil
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
