Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Distributor
Setup fo boring distributor bushings
Checked the tram of the point plate base to the clamp down ridge, no variance (.0004). Trammed in the outer OD to within .0004. Should be able to bore and ream in this setup.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
