Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6G3-1
Main Gear
Cleaned up the table and put the gear up and checked all dimensions. Angles and lengths are within tolerance.
Smoothed out surfaces and radi, filed off all sharp edges.
Used 1/8" roundover bit in router to put 3mm radius on the upper edges that fit in the chanel.
Used two clamps to stabilize part, routed half way then moved clamps to other side, then routed the side that was clamped.
Inspection passed
1/8" roundover bit
Clamp part to stabilize
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
