Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Weld canopy hinge / engine mounts
Removed the cables from the canopy frame and the guide brackets. I will be modifying this for the 650 like closing mechanism.
Using washers for spacing and the canopy steel frame for location, welded the tabs on the engine / canopy hinge and closed up the corner also
Old cable
Tabs
Closed corners
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
