Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6b20-4
Layout, cut, and bend air vents 1 of 5
Made a 2D cad layout using ViaCad from the given dimensions and adding margins to accommodate the 2" dia hose I plan to use.
Made layout on metal and cut it out leaving extra to close the hose end. Only made splits up to the bend lines there.
Transfered the layout to another piece for the other side.
Cad layout with dimensions
Initial layout
Transfered layout
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
