Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6b15-4
Prep corners for NutPlates MS21075L3
Make washers, drill rivet holes for nutplates.
Used hardwood and large center punch to dimple for nutplates. The rivet holes are to close the the flange to use the standard tools.
Need to make a hardened 4140 x 3/8 dia tool to close up from the back side.
NutPlates MS21075L3
Make washers
Set rivets
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
