Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Lower LG Bearing
There is about 6mm of extra material in the middle. Layout lines and cut on band saw to seperate the two halves.
Size needs to be 1.85". Get setup on one side then mill split surface fully, swap halves and macinie the other side. Bolt together and check for fit.
Layout split line
Machine to size
Check for fit
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
