Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Lower LG Bearing
Setup in vice and carved (milled) out the 12 degree angles and middle slot.
Now I need to split the part, bolt together and bore the 2" hole for the gear leg.
Long drill bit for finishing holes
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
