Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6B8-6
Fabricate Upper Bearing for Nose Gear
Cut and layed out bolt holes holes in the .5" Nyloil that I got locally. I will machine it down to .25"
Fit and bolted to 6B7-1, indicated 2" hole and opened up the Nyloil hole to 2".
Cut down around the bolt to .25 to see how the fit is with the rivet that is inline with the bolts. Might have to shorten two rivets here.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
