Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Nose Bowl
Slot base and backbone, layout/trim stations
Took everything apart and sloted backbone and base for the bottom stations. Reassembled and set stations in their slots.
I was able to use two of the prior templates to capture the shapes from the part station lines. That made the layout go much faster.
Trimmed the forward ends so the disks can sit on them.
Went to pick up the motorcycle, new tires for the ride down to SnF 2009.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
