Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6b6-4
Bend Upper Engine Mount & Canopy Hinge 2 of 3
Just using wood will leave springback in the bend, but no marks on the part.
I used the vice with hardwood soft jaws to close up the bend to 90 degrees.
Clamped anvil and bent small tab on bench by hand. Touched it up and qualified part to proper angle.
Has a little springback
Removing springback
Bending small flange
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
