Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6b8
Layout and locate 6b8-11 & 6b8-10
Clamping pre drilled 6b8-11 to 6b7-1. Using flat blocks to keep everything in line prior to drilling through 6b7-1.
The rivet from 6b8-10 will hit the 12mm flange on 6b8-1. So I used pliers to bend the flange away locally.
Cleared out the 2" hole where it passe through 6b8-11
Open rivets holes for the A5's.
Clamping 6b8-11
Bent 12mm flange to clear rivet
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
