Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-b4-2
Cable outlet farings 1 of 2
Attached lower rear hinge and ran some string into the cable opening of the side skin. Held string tight and marked the line the cable will travel on the skin.
Transfered that line to the fairlead
Then screwed both to a board to mill the 1/8" slot.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
