Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-b-4
Attach 6-b-3-6 and L-angles 2 of 3
Marked and pilot drilled end holes (not the upper hinge bolt holes) in upper longerons to establish the rest of the rivet spacing.
Layout and pilot drill 6-b-3-6 for all the rest of the rivet holes except for the very forward ones for 6-b-12-3 bulkhead.
Set and clecoed 6-b-3-6 on top of the longerons and use it as a template to pilot drill the longerons and H.T's
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
