Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-b-3
Get sides ready to hang on floor
Trimmed the lower end of the L-angles, put the 45 on em and joggled the front two.
Drilled out the L-angles to #30 and copper clecoed in the sides. I should be able to just slide the assembly on to the floor and line things up.
Cut and glued up some hardwood to make the Cable Outlet Farings.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
