Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-b-3-8
Fitting access door
To get things to lay down flat I plan to use flush rivets. Here I test the concept by placing 5 tack rivets and installing all the screws.
Both frame and skin get dimpled separately then tack riveted in place.
All screws are installed and the ones that won't thread are reamed out with a .220 reamer.
All screws are tightened.
Dimple skin and frame piece
.220" reamer
Tighten screws
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
