Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Make gust locks for wing storage
Took some wood and lashing strap from Harbor Freight and made two gust locks for $4 total.
With a .5dia ball nose end mill, carve slots in plywood to hold the dowels in place.
With a .625 end mill make a slot through .8 long on center so the strap won't lock down under the dowel.
With a little rubber on the faces it should stay in place.
As they are they will work for now and when I transport the wings to the hanagar.
Gust lock parts
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
