Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Stake wires to ribs
Used a wire ties to help apply some tension on wire bundle between ribs. Stripped ends then applied primer to all the touching surfaces. Let the primer dry with the heat on.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
