Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Make tie rod for Right Aileron 1 of 2
Ream bellcrank for 5/16 bolt. Attach rod ends to bellcrank and aileron.
Shim flap 3mm away from rear spar edge.
Clamp Aileron to flap for neutral position.
Wedge bellcrank to middle position with L-Angles.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
