Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-K-1-2
Tank End Access Cover 1 of 6
Layed it out on the inside using the cover and see through templates.
1st. lay cover between ribs and offest from main spar. Draw outline around each end and all screw holes.
Cover and templates
Position and trace outlines
Initial layout
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
