Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-W-08AA
Rivet nose ribs
I adjusted rib one and two to improve allignment. They were a little low on the bottom and a little high on the top. Used the variance in rivet hole size to adjust.
Transfered the rivet lines to from the nose ribs to align with rear ribs.
That looks better
Nose Ribs 1, 2 , & 3
Rivet lines on nose ribs.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
