Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Rear Rib 9 repair
RR#9 needed repair because I trimmed all rear ribs the same to clear the spar caps. Well the spar caps don't go out that far and I missed the note.
Made up an angle and joggled the ends to make one line against the spar web tip.
Overlaped the angle to the inside of the rib and made up a pattern for the rivets for strength.
Inboard side of rr9
Outboard side of rr9
rr 9 in place on main spar
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
