Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-W-7A
Rear rib assembly process 3 of 3
Put two clecoes in the rib and drill out the center hole if all looks right. Insert cleco in middle hole and drill the other two holes.
Repeat the process for all the rear ribs.
It moved along much faster now that I've done one. RR 9 needs spar web holes layed out and drille before it can be set in place.
Pilot drill middle hole
Add cleco to middle hole
End of the day
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
