Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-W-7A
Rear rib assembly process 1 of 3
Locate rear rib and space evenly between spar caps top to bottom.
Line up the line and mark through spar web pilot hole.
Remove rib and center punch the one hole, I started with the top hole first.
Position rib
Line up line and mark
Marked line
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
