Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Fuel Tank Wiring
Routed the fuel tank sending unit wires through the nose rib tips. The holes were there so I opened em up for gormetts and threaded the wires through. Adde a ground wire from the tank to the rib. I can access it from the inspection hole.
Sending unit wires & tank ground
Wire Rounting
Wire run
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
