Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6K1-1
Fitting Left Fuel Tank
Mark the quick drain location. One cork strip thick on the tank bottom, used three full length strips to distribute the load.
Image 2) Two cork strips thick along the spar to accomadate for the compression of the rivet heads.
Image 3) One cork strip thick on the bottom in three places along the length of the tank.
Mark tank quick drain location
Done for the night
Spar and Bottom Cork strips
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
