Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W9-4
Designing Form for light bubble
Positioned the light base surface against the other template and allowed for the radii of about .5".
Image 2) Cut four 3/4" x 90mm plywood boards for the glue up.
Glue up the block and cut the shape into it.
Light Base Surface
3/4" x 90mm x ?? long
Glue Up block
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
