Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W9
Fitting frame on wing tip
Adjusted the flanges hole to hole for flat keeping the bar parallel to the main spar. Checked again with a flat plate then removed the flanges and deburred everything before re assembly.
Long straight bar
Adjust flange straight
So the bar lays flat
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
