Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W9
Frame bottom edge of wing tip
Opened one of the L angles to 45 degrees and layed out holes and tangent points.
Image 2) Want to keep the crimps close to the edge, using the center line of the rivet holes as a visual gage.
Image 3) Need to stretch the edge some more. Have been using a finish hammer and a steel block, lots of controlled hits gets it moving.
Angle for the bottom wing tip
Only crimp to the hole line
Need to stretch the flange
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
